Updated 2025-02-20
Set Up OCI Terraform
Set up Oracle Cloud Infrastructure Terraform provider scripts, documented in the Terraform Registry, to connect to an OCI account. Confirm the setup by fetching information from the tenancy.
Key tasks include how to:
  • Create RSA keys.
  • Set up Oracle Cloud Infrastructure Terraform provider scripts:
    • Authenticate your Terraform scripts.
    • Get information about the availability domains in your tenancy.
A diagram of a user connected from a local environment to an Oracle Cloud Infrastructure tenancy. The local environment is Linux and has Terraform installed. There is an arrow from Terraform in the local environment connected to Terraform Registry in the cloud. There is a second arrow from the local environment sending a message to the user's Oracle Cloud Infrastructure tenancy labeled Authenticate?. The third arrow is from the tenancy to the local environment labeled Fetch Data. These arrows suggest that the user has set up their Terraform scripts to be authenticated by their tenancy. The user can then fetch information from the tenancy, by using Terraform and Terraform Registry. In this example, the tenancy displays three availability domains and that is the information that the user is fetching.
For more information, see:
Before You Begin
To successfully perform this tutorial, you must have the following:
Note
This tutorial uses an Oracle Linux VM environment with an AMD shape for its examples, but you can use any environment mentioned in this section.
1. Prepare
Prepare your environment for authenticating and running Terraform scripts. Also, gather the information your account needs to authenticate the scripts.
2. Create Scripts
Create scripts for authentication, to fetch data from your account, and to print outputs.
3. Run Scripts
Run your Terraform scripts. After your account authenticates the scripts, Terraform fetches your tenancy's availability domains.
Was this article helpful?
Updated 2025-02-20
