Free Tier: Install Node Express on an Oracle Linux Instance
In this tutorial, you use an Oracle Cloud Infrastructure Free Tier account to set up an Oracle Linux compute instance. Then, you install a Node Express application and access your new app from the internet. Finally, this tutorial covers all the steps necessary to set up a virtual network for your host and connect the host to the internet.
Key tasks include how to:
  • Set up a compartment for your development work.
  • Install your Oracle Linux instance and connect it to your Virtual Cloud Network (VCN).
    • Set up an Oracle Cloud Infrastructure virtual cloud network and related network services required for your host to connect to the internet.
    • Set up ssh encryption keys to access your Oracle Linux Server.
  • Configure ingress rules for your VCN.
  • Configure NodeJS with an Express framework on your instance.
Here is a simplified diagram of the setup for your Linux instance.
A diagram of the components needed to run a NodeJS app with an Express framework, on Oracle Cloud Infrastructure
For additional information, see:
Before You Begin
To successfully complete this tutorial, you must have the following:
Requirements
  • An Oracle Cloud Infrastructure Free Tier account. Start for free.
  • A MacOS, Linux, or Windows computer with ssh support installed.
1. Set up a Compartment for Development
Configure a compartment for your development.
Create a Compartment
Create a compartment for the resources that you create in this tutorial.
  1. Sign in to the Oracle Cloud Infrastructure Console.
  2. Open the navigation menu and click Identity & Security. Under Identity, click Compartments.
  3. Click Create Compartment.
  4. Fill in the following information:
    • Name: <your-compartment-name>
    • Description: Compartment for <your-description>.
    • Parent Compartment: <your-tenancy>(root)
  5. Click Create Compartment.
Reference: Create a compartment
2. Install an Oracle Linux Instance
Use the Create a VM Instance workflow to create a new compute instance.
The workflow does several things when installing the instance:
  • Creates and installs a compute instance running Oracle Linux.
  • Creates a VCN with the required subnet and components needed to connect the Oracle Linux instance to the internet.
  • Creates an ssh key pair you use to connect to the instance.
Review Installation Steps
To get started installing an instance with the Create a VM instance workflow, follow these steps:
Important
The steps provided are for a Free Tier account. If you are using a paid account, the steps might differ from those shown here.
  1. Click the Oracle Cloud icon to go to the main landing page.
    • Scroll down to Launch Resources.
    • Select Create a VM instance workflow.
    The Create compute instance page is displayed. The page sections include
    • Name and Compartment
    • Placement
    • Security
    • Image and shape
    • Networking
    • Add SSH keys
    • Boot volume
  2. Choose the Name and Compartment.
    Initial Options
    • Name: <name-for-the-instance>
    • Create in compartment: <your-compartment-name>
    Enter a value for the name or use the system supplied default. For compartment, select the default root compartment.
  3. Review the Placement settings.
    • Take the default values. An availability domain is assigned to you.
    The data might look similar to the following:
    Availability domain
    • Availability domain: AD-1
    • Capacity type: On-demand capacity
    • Fault domain: Let Oracle choose the best fault domain
    Note
    For Free Tier, use the Always Free Eligible option for availability domain.
  4. Review the Security settings.
    • Take the default settings.
    The data looks similar to the following:
    Security
    • Shielded instance: Disabled
    • Confidential computing: Disabled
  5. Review the Image and shape settings. Take the default values provided by the workflow.
    Note
    The following is sample data for an AMD virtual machine. The actual values might differ.
    • Image: Oracle Linux 8
    • Image build: <current-build-date>
    • Shape: VM.Standard.E2.1.Micro
    • OCPU: 1
    • Memory (GB): 1
    • Network bandwidth (Gbps): 0.48
    Note
    For Free Tier, use Always Free Eligible shape options.
  6. Review the Networking settings. Make the following changes to the default.
    • Click Edit.
    • Primary Network: Select Create new virtual cloud network.
    • New virtual cloud network name: Take the generated VCN name or provide your own name.
    • Create in compartment: <root-for-your-tenancy>.
    • Subnet: Select Create new public subnet.
    • New subnet name: Take the generated subnet name or provide your own name.
    • CIDR block: Take the default value (for example, 10.0.0.0/24).
    • Public IPv4 address, take the default value of Assign a public IPv4 address.
    • Continue to the next section.
  7. Review the Add SSH keys settings. Take the default values provided by the workflow.
    • Select the Generate a key pair for me option.
    • Click Save Private Key and Save Public Key to save the private and public SSH keys for this compute instance.
    If you want to use your own SSH keys, select one of the options to provide your public key.
    Note
    Put your private and public key files in a safe location. You can't retrieve keys again after the compute instance has been created.
  8. Review the Boot volume settings. Take the default values provided by the workflow.
    Leave the Use in-transit encryption setting checked.
  9. Click Create to create the instance. Provisioning the system might take several minutes.
You have successfully created an Oracle Linux instance to run an Apache Web Server.
3. Enable Internet Access
The Create a VM Instance wizard automatically creates a VCN for your instance. You add an ingress rule to your subnet to allow internet connections on port 3000.
Create an Ingress Rule for your VCN
Follow these steps to select your VCN's public subnet and add the ingress rule.
  1. Open the navigation menu and click Networking, and then click Virtual Cloud Networks.
  2. Select the VCN you created with your compute instance.
  3. With your new VCN displayed, click <your-subnet-name> subnet link.
    The public subnet information is displayed with the Security Lists at the bottom of the page. A link to the Default Security List for your VCN is displayed.
  4. Click the Default Security List link.
    The default Ingress Rules for your VCN are displayed.
  5. Click Add Ingress Rules.
    An Add Ingress Rules dialog is displayed.
  6. Fill in the ingress rule with the following information.
    Fill in the ingress rule as follows:
    • Stateless: Checked
    • Source Type: CIDR
    • Source CIDR: 0.0.0.0/0
    • IP Protocol: TCP
    • Source port range: (leave-blank)
    • Destination Port Range: 3000
    • Description: Allow HTTP connections
  7. Click Add Ingress Rules.
    Now HTTP connections are allowed. Your VCN is configured for Node Express.
You have successfully created an ingress rule that makes your instance available from the internet.
4. Create a Node Express Application
Next, set up an Express framework on your Oracle Linux instance and then create and run a NodeJS application.
Install and Set up Node Express
Follow these steps to set up your instance and build your application:
  1. Open the navigation menu and click Compute. Under Compute, click Instances.
  2. Click the link to the instance you created in the previous step.
    From the Instance Details page look in the Instance Access section. Copy the public IP address the system created for you. You use this IP address to connect to your instance.
  3. Open a Terminal or Command Prompt window.
  4. Change into the directory where you stored the ssh encryption keys you created for this tutorial.
  5. Connect to your instance with this SSH command:
    ssh -i <your-private-key-file> opc@<x.x.x.x>
    Since you identified your public key when you created the instance, this command logs you into your instance. You can now issue sudo commands to install and start your server.
  6. Enable HTTP connection on port 3000.
    sudo firewall-cmd --permanent --add-port=3000/tcp
    sudo firewall-cmd --reload
  7. Install the latest version of NodeJS.
    sudo yum update
    sudo yum install -y nodejs
    node --version
  8. Create a directory for your application.
    mkdir node-hello-app
  9. Change to the node-hello-app directory.
    cd node-hello-app
  10. Use npm to create a package.json file:
    npm init
    Enter information as follows:
    • name: node-hello-app
    • version: 1.0.0
    • description: Node Express Hello application
    • entry point: app.js (Don't use the default.)
    • test command: (leave-blank)
    • git repository: git://github.com/username/repository.git (or replace with a valid git repository)
    • keywords: (leave-blank)
    • author: Example User <username@example.com>
    • license: UPL-1.0
    Preview what you get in package.json.
    About to write to /home/opc/node-hello-app/package.json:
      "name": "node-hello-app",
      "version": "1.0.0",
      "description": "Node Express Hello application",
      "main": "app.js",
      "scripts": {
        "test": "echo \"Error: no test specified\" && exit 1"
      "repository": {
        "type": "git",
        "url": "git://github.com/username/repository.git"
      "author": "Example User <username@example.com>",
      "license": "UPL-1.0",
      "bugs": {
        "url": "https://github.com/username/repository/issues"
      "homepage": "https://github.com/username/repository#readme"
    Enter yes to approve your answers.
  11. Install Express and save it in the dependencies list of package.json.
    npm install express --save
  12. Verify that express is added as a dependency in package.json.
    cat package.json
    "dependencies": {
        "express": "^4.17.1"
  13. Create a "Hello, World!" application.
    Create the file:
    vi app.js
    In the file, input the following text and save the file:
    const express = require('express')
    const app = express()
    app.get('/', function (req, res) {
      res.send('Hello World!')
    app.listen(3000, function() {
      console.log('Hello World app listening on port 3000!');
  14. Run the NodeJS program:
    node app.js
  15. Test the application using the command line or a browser:
    • To test with curl, from a new terminal, connect to your Ubuntu instance with your SSH keys, and then in the command line enter: curl -X GET http://localhost:3000
    • From a browser, connect to the public IP address assigned to your instance: http://<x.x.x.x>:3000
    The Node app returns Hello World! on your instance, or in your browser.
You have successfully created a local NodeJS application in an Express framework, on an Oracle Cloud Infrastructure instance.
References:
For more information on Express, see:
