Kubernetes Using Cloud Shell: Deploy a Java Helidon Application
In this tutorial, you use an Oracle Cloud Infrastructure account to set up a Kubernetes cluster. Then, you deploy a Java Helidon application to your cluster using Cloud Shell.
Key tasks include how to:
  • Create a Compartment.
  • Set up a Kubernetes cluster on OCI.
  • Build a Java Helidon application and Docker image.
  • Push your image to Container Registry.
  • Use Cloud Shell to deploy your Docker application to your cluster.
  • Connect to your application from the internet.
A diagram of the components needed to run a Helidon app on Oracle Cloud Infrastructure Container Engine by using Cloud Shell
For additional information, see:
Before You Begin
To successfully perform this tutorial, you must have the following:
Requirements
  • A paid Oracle Cloud Infrastructure account. See Signing Up for Oracle Cloud Infrastructure.
  • Cloud Shell provides the following applications:
    • JDK 8+
    • Python 3.6.8+
    • Kubectl 1.18.10+
    • Apache Maven 3.5+
    • Docker 19.0.11+
Note
The advantage of using Cloud Shell is all the required tools to manage your application are already installed and ready to use.
1. Prepare
Prepare your environment to create and deploy your application.
Check your Service Limits
  1. Log in to the Oracle Cloud Infrastructure Console.
  2. Open the navigation menu, and click Governance and Administration. Under Governance, click Limits, Quotas and Usage.
  3. Find your service limit for Regions:
    • Filter for the following options:
      • Service: Regions
      • Scope: Tenancy
      • Resource: Subscribed region count
      • Compartment: <tenancy-name> (root)
    • Find service limit:
      • Limit Name: subscribed-region-count
      • Service Limit: minimum 2
  4. Find your available Compute core count for the VM.Standard.E3.Flex shape:
      • Service: Compute
      • Scope: <first-availability-domain>. Example: EMlr:US-ASHBURN-AD-1
      • Resource: Cores for Standard.E3.Flex and BM.Standard.E3.128 Instances
    • Find available core count:
      • Limit Name: standard-e3-core-ad-count
      • Available: minimum 1
    • Repeat for Scope: <second-availability-domain> and <third-availability-domain>. Each region must have at least one core available for this shape.
  5. Find out if you have 50 GB of Block Volume available:
      • Service: Block Volume
      • Resource Volume Size (GB)
      • Limit Name: total-storage-gb
      • Available: minimum 50
    • Repeat for Scope: <second-availability-domain> and <third-availability-domain>. Each region must have at least 50 GB of block volume available.
  6. Find out how many Flexible Load Balancers you have available:
      • Service: LbaaS
      • Scope: <your-region>. Example: us-ashburn-1
      • Resource: <blank>
    • Find the count for the following shapes
      • Limit Name: lb-flexible-bandwidth-count
Note
This tutorial creates three compute instances with a VM.Standard.E2.1 shape for the cluster nodes. To use another shape, filter for its core count. For example, for VM.Standard2.4, filter for Cores for Standard2 based VM and BM Instances and get the count.
For a list of all shapes, see VM Standard Shapes.
Note
This tutorial creates three compute instances with a VM.Standard.E3.Flex shape for the cluster nodes. To use another shape, filter for its core count. For example, for VM.Standard2.4, filter for Cores for Standard2 based VM and BM Instances and get the count.
Note
This tutorial uses a 'Quick Create' workflow to create a cluster with a public regional subnet that hosts a flexible load balancer. To use a different load balancer, you can use a custom workflow to explicitly specify which existing network resources to use, including the existing subnets in which to create the load balancers.
To use another bandwidth for the load balancer, filter for its count, for example 100-Mbps bandwidth or 400-Mbps bandwidth.
Create an Authorization Token
  1. In the Console's top navigation bar, click the Profile menu (your avatar).
  2. Click your username.
  3. Click Auth Tokens.
  4. Click Generate Token.
  5. Give it a description.
  6. Click Generate Token.
  7. Copy the token and save it.
  8. Click Close.
Note
Ensure that you save your token right after you create it. You have no access to it later.
Gather Required Information
  1. Collect the following credential information from the Oracle Cloud Infrastructure Console.
    • Tenancy name: <tenancy-name>
      • Click your Profile menu (your avatar) and find your Tenancy:<tenancy-name>.
    • Tenancy namespace: <tenancy-namespace>
      • Click your Profile menu (your avatar).
      • Click Tenancy: <tenancy-name>.
      • Copy the value for Object Storage Namespace.
      Note
      For some accounts, tenancy name and namespace differ. Ensure that you use namespace in this tutorial.
    • Tenancy OCID: <tenancy-ocid>
      • Click your Profile menu (your avatar), then click Tenancy:<tenancy-name>, and copy OCID.
    • Username: <user-name>
    • User OCID: <user-ocid>
      • Click your Profile menu (your avatar), then click User Settings, and copy OCID.
  2. Find your region information.
    • Region: <region-identifier>
      • In the Console's top navigation bar, find your region. Example: US East (Ashburn).
      • Find your Region Identifier from the table in Regions and Availability Domains.
      • Example: us-ashburn-1.
    • Region Key: <region-key>
  3. Copy your authentication token from Create an Authentication Token section.
    • Auth Token: <auth-token>
2. Set Up a Cluster
Install and configure management options for your Kubernetes cluster. Later, deploy your application to this cluster.
Add Compartment Policy
If your username is in the Administrators group, then skip this section. Otherwise, have your administrator add the following policy to your tenancy:
allow group <the-group-your-username-belongs> to manage compartments in tenancy
With this privilege, you can create a compartment for all the resources in your tutorial.
Steps to Add the Policy
  1. In the Console's top navigation bar, open the Profile menu (your avatar).
  3. In the left pane, click Groups.
  4. In a notepad, copy the Group Name that your username belongs.
  5. Open the navigation menu and click Identity & Security. Under Identity, click Policies.
  6. Click Create Policy.
  7. Fill in the following information:
    • Name: manage-compartments
    • Description: Allow the group <the-group-your-username-belongs> to list, create, update, delete and recover compartments in the tenancy.
    • Compartment: <your-tenancy>(root)
  8. For Policy Builder, click Show manual editor.
  9. Paste in the following policy:
  10. Click Create.
Reference
The compartments resource-type in Verbs + Resource-Type Combinations for IAM
Create a compartment for the resources that you create in this tutorial.
  2. Open the navigation menu and click Identity & Security. Under Identity, click Compartments.
  3. Click Create Compartment.
  4. Fill in the following information:
    • Name: <your-compartment-name>
    • Description: Compartment for <your-description>.
    • Parent Compartment: <your-tenancy>(root)
  5. Click Create Compartment.
Reference: Create a compartment
Add Resource Policy
allow group <the-group-your-username-belongs> to manage all-resources in compartment <your-compartment-name>
With this privilege, you can manage all the resources in your compartment, essentially giving you administrative rights in that compartment.
  1. Open the navigation menu and click Identity & Security. Under Identity, click Policies.
  2. Select your compartment from the Compartment list.
  3. Click Create Policy.
    • Name: manage-<your-compartment-name>-resources
    • Description: Allow users to list, create, update, and delete resources in <your-compartment-name>.
  5. For Policy Builder, select the following choices:
    • Policy use cases: Compartment Management
    • Common policy templates: Let compartment admins manage the compartment
    • Groups: <the-group-your-username-belongs>
  6. Click Create.
Reference
Common Policies
Create a Cluster with 'Quick Create'
Create a cluster with default settings and new network resources through the 'Quick Create' workflow.
  1. Sign in to the Oracle Cloud Infrastructure Console.
  2. Open the navigation menu and click Developer Services. Under Containers & Artifacts, click Kubernetes Clusters (OKE).
  3. Click Create Cluster.
  4. Select Quick Create.
  5. Click Launch Workflow.
    The Quick Create Cluster dialog is displayed.
  6. Fill in the following information.
    • Name: <your-cluster-name>
    • Compartment: <your-compartment-name>
    • Kubernetes Version: <take-default>
    • Kubernetes API Endpoint: Public Endpoint
      The Kubernetes cluster is hosted in a public subnet with an auto-assigned public IP address.
    • Kubernetes Worker Nodes: Private Workers
      The Kubernetes worker nodes are hosted in a private subnet.
    • Shape: VM.Standard.E3.Flex
    • Select the number of OCPUs: 1
    • Amount of Memory (GB): 16
    • Number of Nodes: 3
    • Network Bandwidth: 1.0 (This value is calculated by OCPU count.)
    • Max Total VNICs: 2 (This value is calculated by OCPU count.)
  7. Click Show Advanced Options.
    Keep the defaults.
    • Specify a custom boot volume size: Clear the check box.
    • Image Verification: Clear the check box.
    • Add an SSH key: No SSH key
  8. Click Next.
    All your choices are displayed. Review them to ensure that everything is configured correctly.
  9. Click Create Cluster.
    The services set up for your cluster are displayed.
  10. Click Close.
  11. Get a cup of coffee. It takes a few minutes for the cluster to be created.
You have successfully created a Kubernetes cluster.
Configure Cloud Shell to Access to Your Cluster
After you create a Kubernetes cluster, set up Cloud Shell to access the cluster.
  3. Click the link to <your-cluster>.
    The information about your cluster is displayed.
  4. Click Access Cluster.
  5. Click Cloud Shell Access. Follow the steps in the dialog. The following steps are provided for your reference.
  6. Click Launch Cloud Shell. Alternatively, from the main menu, you can click the Cloud Shell icon (cloud-shell-icon) and start a session.
  7. Check your oci CLI version and verify that Cloud Shell is working.
    oci -v
  8. Create kubeconfig file for your setup. Use the information from Access Your Cluster dialog.
    oci ce cluster create-kubeconfig <use data from dialog>
    You get a message that:
    New config written to the Kubeconfig file <your-home-directory>/.kube/config
    Note
    If the config file is not stored in its default location (~/.kube/config, you must export the KUBECONFIG environment variable to point to the location.
    export KUBECONFIG=$HOME/<new-location>/config
    Note
    When working with more than one cluster, you specify a specific config file on the command line. Example:
    kubectl --kubeconfig=</path/to/config/file> <some-command>
  9. Test your cluster configuration with the following command.
    List clusters:
    kubectl get service
With your cluster access setup, you are now ready to prepare your application for deployment.
3. Build your Docker Application
Next, set up Helidon MP on Cloud Shell. Then, create and run a Helidon application.
Create a Local Application
Create your Java Helidon application.
  1. Start Cloud Shell.
  2. At the shell prompt, run the following Maven Archetype to create a Maven project template. This project uses the Helidon Quick Start MP example from the Helidon website.
    mvn archetype:generate -DinteractiveMode=false \
                            -DarchetypeGroupId=io.helidon.archetypes \
                            -DarchetypeArtifactId=helidon-quickstart-mp \
                            -DarchetypeVersion=1.4.8 \
                            -DgroupId=io.helidon.examples \
                            -DartifactId=helidon-quickstart-mp \
                            -Dpackage=io.helidon.examples.quickstart.mp
    The Archetype creates a Maven project under the current directory. You get the following output:
    [INFO] Project created from Archetype in dir: /home/your_user_id/helidon-quickstart-mp
    [INFO] BUILD SUCCESS
  3. Change to the helidon-quickstart-mp directory.
    cd helidon-quickstart-mp
  4. Build the application.
    mvn package
    You get a success message.
You have successfully built the Helidon application.
Run the Local Application
Run your Java Helidon application.
  1. Run the application.
    java -jar target/helidon-quickstart-mp.jar
    After the application has started, move the application to the background.
    1. Press Ctl-z.
    2. Type: bg
    The Helidon application is now running in the background.
  2. Test the application using curl.
    • To get a "Hello World!" message, enter:
      curl -X GET http://localhost:8080/greet
    This message is returned: {"message":"Hello World!"}.
  3. Enter a name for the greeting.
    Enter the following command:
    curl -X GET http://localhost:8080/greet/Mike
    This message is returned: {"message":"Hello Mike!"}.
  4. Update the greeting.
    From the terminal, enter:
    curl -X PUT -H "Content-Type: application/json" -d '{"greeting" : "Aloha"}' http://localhost:8080/greet/greeting
    This command updates the Hello in the message to Aloha.
  5. Test the updated greeting.
    You see {"message":"Aloha Mike!"}.
  6. Enter the following command to get the metrics from your Helidon application.
    curl -H 'Accept: application/json' -X GET http://localhost:8080/metrics
  7. Stop the running application.
    • When you are done testing, get the process ID for your application.
      ps -ef
    • Stop the process.
      kill <your-pid>
You have successfully created a Hello World application using the Helidon MicroProfile service on Oracle Cloud Shell.
References:
Build a Docker Image
Next, create a Docker image for your Helidon application.
  1. Ensure you are in the helidon-quickstart-mp directory.
  2. Build a Docker image.
    docker build -t helidon-quickstart-mp .
    Successfully tagged helidon-quickstart-mp:latest
  3. Run the Docker image:
    docker run --rm -p 8080:8080 helidon-quickstart-mp:latest &
  4. Test the application.
  5. Stop the running application.
Congratulations! You have successfully created a Helidon Docker image.
4. Deploy Your Docker Image
With your Helidon image created, now you can deploy it.
Create a Docker Repository
  1. Open the navigation menu and click Developer Services. Under Containers & Artifacts, click Container Registry.
  2. In the left navigation, select <your-compartment-name>.
  3. Click Create Repository.
  4. Create a private repository with your choice of repo name:
    <repo-name> = <image-path-name>/<image-name>
    Example: helidon-apps/helidon-quickstart-mp
    You are now ready to push your local image to Container Registry.
    Note
    Before you can push a Docker image into a registry repository, the repository must exist in your compartment. If the repository does not exist, the Docker push command does not work correctly.
    Note
    The slash in a repository name does not represent a hierarchical directory structure. The optional <image-path-name> helps to organize your repositories.
Push Your Local Image
With your local Docker image created, push the image to the Container Registry.
Follow these steps.
  1. Open a terminal window.
  2. Log in to OCI Container Registry:
    docker login <region-key>.ocir.io
    You are prompted for your login name and password.
    • Username: <tenancy-namespace>/<user-name>
    • Password: <auth-token>
  3. List your local Docker images:
    docker images
    The Docker images on your system are displayed. Identify the image you created in the last section: helidon-quickstart-mp
  4. Tag your local image with the URL for the registry plus the repo name, so you can push it to that repo.
    docker tag <your-local-image> <repo-url>/<repo-name>
    • Replace <repo-url> with:
      <region-key>.ocir.io/<tenancy-namespace>/
    • Replace <repo-name> with:
      <image-folder-name>/<image-name> from the Create a Docker Repository section.
    • Here is an example after combining both:
      docker tag helidon-quickstart-mp iad.ocir.io/my-namespace/helidon-apps/helidon-quickstart-mp
      In this example, the components are:
      • Repo URL: iad.ocir.io/my-namespace/
      • Repo name: helidon-apps/helidon-quickstart-mp
    Note
    OCI Container Registry now supports creating a registry repo in any compartment rather than only in the root compartment (tenancy). To push the image to the repo you created, combine the registry URL with the exact repo name. OCI Container Registry matches the unique repo name and pushes your image.
  5. Check your Docker images to see if the image is copied.
    docker images
    • The tagged or the copied image has the same image ID as your local image.
    • The copied image name is:
      <region-key>.ocir.io/<tenancy-namespace>/<image-folder-name>/<image-name>
  6. Push the image to Container Registry.
    docker push <copied-image-name>:latest
    Example:
    docker push iad.ocir.io/my-namespace/helidon-apps/helidon-quickstart-mp:latest
  7. Open the navigation menu and click Developer Services. Under Containers & Artifacts, click Container Registry.
Find your image in Container Registry after the push command is complete.
Deploy the Image
With your image in Container Registry, you can now deploy your image and app.
  1. Create a registry secret for your application. This secret authenticates your image when you deploy it to your cluster.
    To create your secret, fill in the information in this template .
    kubectl create secret docker-registry ocirsecret --docker-server=<region-key>.ocir.io  --docker-username='<tenancy-namespace>/<user-name>' --docker-password='<auth-token>'  --docker-email='<email-address>'
    After the command runs, you get a message similar to: secret/ocirsecret created.
  2. Verify that the secret is created. Issue the following command:
    kubectl get secret ocirsecret --output=yaml
    The output includes information about your secret in the yaml format.
  3. Determine the host URL to your registry image using the following template:
    <region-code>.ocir.io/<tenancy-namespace>/<repo-name>/<image-name>:<tag>
    Example:
  4. On your system, create a file called heli-app.yaml with the following text:
    Replace the following place holders:
    • <your-image-url>
    • <your-secret-name>
    apiVersion: apps/v1
    kind: Deployment
    metadata:
    spec:
      selector:
        matchLabels:
          app: app
      replicas: 3
      template:
        metadata:
          labels:
            app: app
        spec:
          containers:
          - name: app
            image: <your-image-url>
            imagePullPolicy: Always
            ports:
            - name: app
              containerPort: 8080
              protocol: TCP
          imagePullSecrets:
            - name: <your-secret-name>
    apiVersion: v1
    kind: Service
    metadata:
      labels:
        app: app
      annotations:
        service.beta.kubernetes.io/oci-load-balancer-shape: "flexible"
        service.beta.kubernetes.io/oci-load-balancer-shape-flex-min: "10"
        service.beta.kubernetes.io/oci-load-balancer-shape-flex-max: "100"
    spec:
      type: LoadBalancer
      ports:
      - port: 8080
      selector:
        app: app
  5. Deploy your application with the following command.
    kubectl create -f heli-app.yaml
    Output:
    deployment.apps/heli-app created
    service/heli-app-lb created
    Note
    In the heli-app.yaml file, the code after the dashes adds a flexible load balancer.
Test Your App
After you deploy your app, it might take the load balancer a few seconds to load.
  1. Check if the load balancer is live:
    kubectl get service
    Repeat the command until load balancer is assigned an IP address.
    Note
    While waiting for the load balancer to deploy, you can check the status of your cluster with these commands:
    • Get each pods status: kubectl get pods
    • Get app status: kubectl get deployment
  2. Use the load balancer IP address to connect to your app in a browser:
    http://<load-balancer-IP-address>:8080/greet
    The browser displays: {"message":"Hello World!"}
  3. Undeploy your application from the cluster. (Optional) To remove your application run this command:
    kubectl delete -f heli-app.yaml
    Output:
    deployment.apps/heli-app deleted
    service "heli-app-lb" deleted
    Your application is now removed from your cluster.
What's Next
You have successfully created a Helidon MicroProfile Hello World application, deployed it to a Kubernetes cluster, and accessed the app from the internet.
Check out these sites to explore more information about development with Oracle products:
